You can adjust the rear Springs to the max.
You can buy heavier rear Springs.
You can replace the motion contol Shock with a rebuildable HPG Shock. ( I buy them from DeyCore in MN)
The Center Spring adjustment will not help with the bottoming out issue in the rear. The center Shock/Spring is
for weight transfer to the Ski's mostly.
