skidoo500s
Hi i was wondering what the adjustment screw that pushes down on the throttle shaft does. If ur not sure where the throttle shaft is located well it is in between the two carbs and there is a braket holding a screw and that screw then pushes down onto the throttle shaft so i was wondering what that screw did.
Some possiable thoughts i got that it could be is the main idle for the two carbs.
