m8man, Snap Stone is some pretty nice stuff! It went right over the top of some crappy linoleum stuff in our entryway. I "taught myself" how to cut with the wet saw
($60@Mennards). The wet saw works great for cutting Plexiglas too, but that's another project.
Whole project took 2 1/2 nights after work including two closet areas. Those were a little trickier, but now I'm ready for the kitchen & hallway leading to the bathroom. Still gets grouted like regular tile. The cost difference is pretty much a wash when you add it all up. Plus you're able walk on it immediately, even when half done. Just vacuum again before continuing the next day. The only exception is the grout step which needs to dry over night.
For the tile purest, this may not be the way to go. For the DIY home guy, just get it and don't look back. Aside from pulling the baseboards, to see if it's floating or regular, nobody will ever know. Very professional looking and easy to install. Wet areas are fine too. Seals up just as good or better than traditional. Just have to silicon the edges which does not affect the float.
You won't be disappointed. Cheers.
