Do sled batteries come in different cranking amps? If so is it okat to go to a higher cranking amp battery without wrecking or burning anything up in the wiring. My 800 RMK needs a way better initial crank over at cold start then the stock battery can give.
Kip and Poo guys, I hope you can answer what battery I should buy, Brand, amps, etc.
I don't mind pulling the rope, but Electric start is nice when pull rope side is hanging out in mid air on the side of a mountain.
