I'm not sure, like you, this is too new & I haven't had a ton of time fo figure things out. I wish I had an answer for you, maybe one of the mods can chime in, but, they are also new to the format. If I stumble onto how, I will share that with you.That's an option thank you. However is there a way to do what I want?
Scroll down for some visual help.Gary, I"m embarrased to say...I don't get it. I don't see "time stamp" anywhere. I want to be able to see the most recent post WITHIN a thread. I use the What's new all the time to see what's changed since the last time I logged in. When I select a particular thread I would like to see the most recent post within that thread at the top and not see the #1 post each time. This is how the old forum was set up and I can't seem to figure out how to rearrange the posts.
You know, when we first launched this I'm quite certain I saw something in regards to the priorities in sorting, most recent verses the oldest. But I'll be darned if I can recall where that was. I'll keep looking, if I find something I'll let you know.Gary, the #1 in my first post indicates its the first post in this particular thread. your most recent post is #9. When I log in and check this thread I want to see your #9 first, on the top then #8 under yours and so on with my #1 post at the bottom. Is there a way to do that? I'm sure it's a simple fix but I cannot figure out how to do that.
