Straightline Performance exhaust for ski doo 1200
dragon_07
I am thinking of getting the lightweight muffler and header from straightline performance for my 2014 renegade with the 1200 4 tec engine. Is anyone running the muffler or header or both? If so are you happy with it for the price?
dragon_07
Out of all the guys on here with 1200's no one is running an aftermarket muffler or header? Is there a different direction I should be looking for performance gains? I did some reading on doo talk and it seemed the header made good hp gains that's why I started inquiring. If there are there are things that work or don't I would like to hear about it before wasting the money, thanks.
russr
if you just install a muffler you will maybe if your lucky pick up 1hp but you will save about 10 lbs off of the sled.
no need to worry about running lean ext with just a muffler change out.
now if you run a header you will need to run a box to keep her safe and get the h.p. out of the engine.
most folks that run the header will also install the pb80 cluch to get all the rpm out of it and h.p.
if you go to dootalk.com you will get all the info your looking for and then some.
