Summer storage - track
mgsimon
I would like all your expert opinions,
Should the track be loosened?
Should track be suspended or just blocked off the floor?
What about front suspension?
Thanks
Mgs
I don't loosen anything but I have a lift so both front and rear suspension hang with no pressure. I bought one two years ago and love it. Works great in the fall for preseason maintenance because you work at waist level.
sweeperguy
I loosen my track, raise it off the deck, and I roll it several times during storage to keep it from having the bend around the idler wheels and drivers in one spot all summer. I've not ever raised the front suspension with coil over shocks. But this year I might because I have Fox Float 2's (air spring) on it now ANY INPUT ON THIS I'D APPRECIATE TOO. I'm also wondering if I should bleed out the air or leave it at the psi I ride at?
srt20
I do nothing on trail sleds. The 2.5" tracks a put a 2x4 under inbetween 2 lugs to keep the lugs from bending over. None issue on my trail sleds.
I don't raise front or rear. I have air shocks in one mtn sled rear suspension and leave it.
I usually have one sled on lift because there is always something to do to them.
