I agree with SeaFoam....no need to drain bowls, spray fog, shrink wrap, take off track, disassemble/repaint or any other over the top summerization......My $.02
My list of summerization to do:
- Sea Foam in tank and run 5-10 minuts to ensure it's in the carb. NO GOOD IF YOU DON'T GET TO CARBS!! (or buy an e-tech...but I will still seafoam it)
- Track off ground, best to get ALL WEIGHT off suspension if possible
- Lube ALL grease zirks, not just rear suspension. You'll be shocked how much moisture will get displaced! (that will make rust if you don't!!)
- Take belt off (otherwise you'll likely corrode (pitt) clutch sheeves at belt contact point)
- Spray all metal surfaces with WD40 (good wash first if you can...NO SPRAY ON CLUTCH!!)
- Blow out clutch with AIR ONLY...Have a good go at it, the dust will fly! Dust = friction.
- Put on cover to keep dust off
