I'm finding these synthetic mid-layers rank-up fairly quick and with these week long trips it's becoming an issue.
Anyone use a poly base with wool blend mid and then maybe a fleece or pile when it's drops below 0? I've read these wool blends don't take on the rank so easily.
I've also read if you're your using any type of Gore-Tex type material for outer layer you need to make sure you build up enough heat to push that moisture out. So it may be best to actually use a lighter weight mids so heat can build and push the moisture out.
