I'm just curious, could you hook up the throttle bodies from a zr 500 efi onto a zl 440?
A acatzl550 New member Dec 11, 2009 #1 I'm just curious, could you hook up the throttle bodies from a zr 500 efi onto a zl 440?
J jimfsr New member Dec 12, 2009 #2 If you mean replace carbs with throttle bodies, short answer is no. If you really wanted to mess around and change all the electronics, re-map the fuel flow and get it all dialed in, then there may be a way to do it. Would it be cost effective...?
