Throttle positioning sensor on 2005 F7
jimfsr
poor running or stumbling-usually noticed in a left turn first as the pressure on the throttle is more up than in. If the sled tries to shut down or stumbles real bad, then recovers when going straight, then the bushings in the throlle lever need to be replaced. that usually takes care of it. Unlike a yamaha you cannot bypass the system by connecting the wires together at the carbs/injectors.
