I have a 2011 crossfire when I switch the thumb warmer to high the warmer doesn't work. When I switch the thumb warmer to low the warmer works but the lights go out. Any body ever had this problem or ideas what might be causing it?
Check the wires going to thumb warmer could have one grounding some were or the thumb warmer it self is grounded out. Had kind of the same problem with a sled I was working on for a friend. Hope this helps.
