S
skylar
This past February while dealing with an issue on my buddy Joe's 900, I had his exhaust off, so I pulled the y pipe to check on the pistons/cylinders. I noticed that the mag side piston was scored pretty bad, he decided to just run it that way until the end of the season. So today I tore into it to check things out further. The mag side cylinder is scored along with the piston, and the piston has a real nice crack in the skirt. The pto side is fine. Luckily that piston skirt didn't break, it would have gotten real expensive if he would have had to put a crank in it. So, there will be new pistons/rings and one new/replated cylinder going on. Hopefully I will have it wrapped up by next weekend. I pulled his radiator out of it also, that gets rid of 7 lbs off the front end.
