Torn carburetor boot
Would a torn boot cause idling problems? The sled wouldn't idle last season and I thought it was a carburetor problem but discovered a torn boot.
Like sweeperguy guy said no doubt can cause a idle problem. It is a vacuum leak causing it to run lean. Seems more common with ethanol in the gas. Has been a problem for Ski-Doo for some time now. Just replace mine on my 16 tnt 600 etech with boysen reeds. There boot is not part of the reed cage.
