this has to do with my boat trailer, but I thought I would check with some JDers. My new boat trailer has surge disc brakes on it. All aluminum Nextrail trailer. It has the back up solenoid that disengages the disc brakes when you back up (at least it's supposed to), which comes off the reverse light circuit when you put your truck in reverse as the center pole in the 7-way factory plug (reverse lights). I was able to confirm that I do NOT have power on that center pole when my truck is in reverse. All other contacts have power according to their purpose (tail, blinker, brake lights, etc.). I traced the wire as far back as I could (factory wiring harness) and have no power for that center pole wire. Very quickly it goes into the master wireing harness under the truck and thus lose the capability to track it back.
Truck is a 02 Chev Avalanche Z-71 5.2l. Everything is factory and stock.
Anybody have any idea if there is a special fuse or something that I need to put in my truck to "activate" the reverse pole on my plug, or is it more likely a bad connection somewhere? I have no idea if that center pole ever worked on my truck as I have never needed the reverse solenoid before.
Any suggestions on how I can trouble shoot? Again, it's not the plug, bc I don't have power for that wire (purple) going into the plug, but I don't even know if that circuit is supposed to be live or if I need to do something to the truck like add a fuse or something? Any help would be appreciated. Thank you.
