LOL now that you have all these opinions your probably scratching your head and thinking "but what do I do" electrical problems are a super pita, you have to eliminate one step then go to another until it's fixed. A newer truck, I doubt if it's in the vehicle, hook black volt meter clamp to the frame make sure it's a good clean hook-up, take red probe with meter set for dc volts, have someone help, step on brake, use turn signals (etc) and check plug-ins in relation to what the helper is doing.
Example: put probe in left turn signal & have helper turn on left turn signal, should be 12 volts maybe alittle more but not less, atleast that would rule out the truck.
If it's a tilt trailer you might be losing ground where the trailer tilts, take a piece of braided wire like they use hooking the motor of the truck to the fire wall and hook one end to the tongue of trailer and the other to the bed. Just my 2 cents worth
