"I got a tester and I when I turn on the hazards I get the tester to light. However, when I put the tester right into the outlet I don't get anything on any of the wires."
If you don't have power at the truck connector, don't waste time checking the trailer. If the trailer is hooked up, it might be getting ground through the coupler and allowing the tester to work with the hazards on.
If you unplug the trailer and aren't getting the tester to light at the connector, check the truck connector for a bad ground connection. Try putting the ground lead of the tester onto the truck frame (chrome bumper) and then checking for power in the connector. On my 03 Chev Silverado, the truck connector has a cable harness plugged into the front of it. Unplug that harness and take a look. If the ground terminal is all green, you found your problem. Clean all the contacts good and put some dielectric grease on them before replugging the harness.
