harski
I have noticed excessive outer tire wear on my 25ft enclosed aluminum trailer and have some concern that I'm hoping others can help with. The tires are two years old and have about 3,500 + miles on them. They are R15 tires on aluminum rims and are mounted on dexter axles. I have been running 48-50 PSI in them and the max rating is 50PSI.
My question is, that the manufacturer couldn't answer, is this normal wear? They suggested to have them balanced as they are not from the factory. My other thought is since they are 3,500# axles is this just normal wear since I'm under max load capacity (only carring 2-3 sleds)? Not sure if these axles have cambar adjustment or not that could help.....
Anyway, thanks in advance for any suggestions or experiences!
Harski
Harski
