Trailer wiring
Gunnywaldo
Anyone ever see this one, I have a 1994 triton 2 place open trailer and I keep blowing the tail/marker lights fuse on the tow vehicle. It appears it is something in that part of the circuit on the trailer.
I haven't started troubleshooting it yet however I know what to do and how to isolate it. Presently the right front side marker light is out.
My question is has anybody ever seen a Triton sealed light assembly fail and cause the fuse to blow?
Thanks
bouncer
Look for the obvious spots were the wires contact or go through the frame. If its a tilt bed look at the pivot point of the trailer were the wires flex when tilting. I have had the sealed taillights burn out. If you suspect the taillight is causing the problem, check them on the bench isolated from the trailer wiring system. Good luck
samc
There was a post about this 2 weeks ago. If you look back/down in the Tech Talk you should be able to locate it.
Gunnywaldo
it's an open trailer
It's an open trailer but the license plate light could be giving me grief, thanks for the thought, i'll check it.
