USAF Thunder landing zone on Michigan State Route M-32 near Alpena
frnash
From Up North Live ABC 74, Alpena, MI, Thursday August 5, 2021 -- see: https://tinyurl.com/r88srnwt
A portion of Michigan Route 32 will be closed [FRN: was closed from 8 a.m. to 1 p.m. on August 5, 2021] for five hours as the U.S. Air Force practices landing an aircraft on roadways designed for cars and trucks.<br>According to the Air Force, the plan is to land four A-10 aircraft and two C-146 aircraft on a closed-off portion of the road near the Alpena Combat Readiness Training Center.<br>This is the first time training like this has taken place in North America.
800etec
i dont get it,,,,,,,,,,they shut down a road to make a vidieo? would somebody help me here,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
racerx
Improvised runway use, they do this kind of training overseas all the time. The purpose is for frontline fighters to be used for emergencies or even field resupply so they do not have to return to a base that may be too far in order to keep the cycle time low. This is more for ground attack aircraft like the A10 and more so helicopters but not so much for the high fliers that have the speed to return.
frnash
i dont get it … they shut down a road to make a vidieo? would somebody help me here …
So you didn't read the text accompanying the first item from Up North Live ABC 7? — No it was NOT done "to make a 'vidieo' [sic] (not even to make a video!) It was a training exercise!
"A portion of Michigan Route 32 will be closed for five hours as the U.S. Air Force practices landing an aircraft on roadways designed for cars and trucks. — "It’s all part of the annual multi-national, large-scale military event, Exercise Northern Strike, hosted by the Michigan National Guard in northern Michigan. — "According to the Combat Readiness Training Center, it's about being ready for any possibility. — “When we’re operating from locations such as Thunder landing zone on M-32 we won’t have those kind of support functions. We have to be able to operate with a small number of people and a very short amount of time," Lt. Col. Brian Wyrzkowski, mission commander for the training, said.
FWIW, the Swedish Air Force has been doing that for some time, see: https://en.wikipedia.org/wiki/Highway_strip#Sweden — I'm sure you could find a number of Youtoob videos of them in action.
frnash
i know this is some kind of a joke but... calling out Frnash, 'Youtoob' [sic]
Yes, a joke, of sorts, although you're right, it was a bit of a typo. It should have been "YootToob"; that's just how I usually spell it. I 'spose I should have tagged it as [sic] to indicate that it was deliberately misspelled — (Insert "devilish" emoji here.)
chords
<img src="<a href=" https:="" forum.johndee.com="" vbulletin="" attachment.php?attachmentid="63273&stc=1""" target="_blank">https://forum.johndee.com/vbulletin/attachment.php?attachmentid=63273&stc=1" attachmentid="63273" alt="" id="vbattach_63273" class="previewthumb">
I have a place on Hubbard Lake about ~20 miles direct South as the F-16 flys from the CRTC formerly the Phelps Collins Field in Alpena, MI. There was a lot of activity in the sky that week. A few hot shots screamed the 7 mi length of the lake at low altitude and pulled up just short of Mt. Maria which rises up abruptly 1,261 ft at the S. End of the lake.
racerx
Was in West Bend last weekend doing some hiking ,and got buzzed, so to speak, by a F16 doing a low level 360 around us. Kinda cool seeing jets doing there thing out in the wild as you don't really see them unless at an air show.
favoritos
Thanks for posting the video. It is dang cool and highlights some of the difficulty.
I worked with cropdusters (in my younger days), and used roads when needed. I usually started those days by scouting out suitable sections of road ahead of the planes arrival. Powerlines and trees add risk more than you might realize. The interesting thing in the video is the hill. There are no approach lights for elevation and then you add in a hill. The cropduster pilots were on the edge of crazy, but they still used flat terrain when they had a choice. They also had the advantage of much slower approach speeds.
The flying in the video is impressive.
I also love to see the Warthogs. There is something about those things that says all business all day.
frnash
… The interesting thing in the video is the hill. There are no approach lights for elevation and then you add in a hill. … I also love to see the Warthogs. There is something about those things that says all business all day.
Yes, I was quite surprised that they chose a 1-mile section of a road with a hill! They couldn't have found a 1-mile section of flat, level road? Perhaps the hill was part of the challenge of the exercise. — About the "approach lights for elevation", yes, and one more thing: Runway lights — I found that I consistently made better, smoother landings at night with runway lights and fewer visual distractions. As mutually parallel lines in three-dimensional space appear to converge, on close-in final approach, the runway lights also appear to converge, but as you descend closer to the runway, they lose the "vanishing point convergence" and appear in your peripheral vision to be more and more parallel. When they are parallel, you're there — touchdown, as smooth as glass. To some extent you can use the same trick in daylight, although there are more visual distractions then. — Such visual cues would be far more limited on the road used in that exercise. — Warthogs: Agreed, If I could fly any military aircraft, forget "Top Gun", the Warthog would definitely be my choice! The greatest close air support aircraft; you can neither see nor even hear them on a low ground hugging approach until it's game over! And to think the Pentagon wanted to kill it, at least since 2015, when with the USAF's budget, the service considered retiring the A-10! Then finally in June 2017, it was announced that the aircraft "...will now be kept in the air force’s inventory indefinitely. Yeay!
chords
That stretch of M-32 was chosen because very few homes if any, but also that 1 mile opens up to 4 lanes for passing. I found aerial footage from the canopy of the landings/takeoff , but wont bother trying to post.
frnash
… That stretch of M-32 was chosen because very few homes if any, but also that 1 mile opens up to 4 lanes for passing. …
That stretch of M-32 was chosen because very few homes if any? — I'll betcha they could have found any number of 1-mile segments of several roads that meet that criteria. Fer sure in the UP, for example along the 20+ miles of boring, hypnotic, sleep inducing straight as an arrow, flat as a pancake Seney Stretch (M-28) between Seney and Shingelton. — Four lanes? All of M-32 consists of rural two-lane highway outside of the city of Gaylord. — For passing? What passing? Passing aircraft? The entire segment was closed traffic!
chords
Ok let me break it down for ya. I'm guessing they wanted a landing zone close to the base which is just a couple miles away also on M-32.<br>Here in MI we have sections of 2 lane roads that widen out to 4 lanes to allow for passing slower moving <strong>vehicles/cars/trucks</strong> This 1 mile section would provide a much wider surface to land on because it is <strong>4 lanes wide</strong>
