alley mechanic
Hello all its been a while since i have been on here, well i just got done replacing the drive shaft bearings on my 2000 zl580 esr i have 2100 miles on it the pto side bearing was bad no grease in it but the angle gear was still working , when i took it apart the set screw was loose and the look collar was also loose mind you i bought this sled brand new , when i opend the chain case i found the long bolt that hold the reverse gear on also loose thank god the locking tab that hold the bolt from turning did its job which leads me to my question , the tear down and put back together went very smooth till i looked at the parts sheets that shows how the parts are put together it seems that i have put the tab lock on the reverse gear first than the washer , i dont think it would hurt any thing cause i dont want to pull it apart for this little issue what do you guys think .
Thank you alley mechanik
