jim_golding
Well my son went to fix his sled which lost spark and lights last year, when I noticed his overflow bottle coolant level to be gone. There were no external leaks. So we remove the plugs and pull it over. Yup water came out both plug holes!! So we started disassembly yesterday. We removed the head and found everything to be in great condition with no signs of leakage or running with any coolant entering the cylinders or visable cracks in the water jackets. So I am thinking the only thing that could cause coolant leakage into both cylinders is the water pump seal which is driven off a shaft that comes out in the middle of the crankcase. Is this a common failure mode of these seals to have it leak into both sides of the crank or are the crank seals between to the two cylinders also shot. We will be pulling the engine today to drain the remaining coolant out of the crankcase and dry it out with WD40 and other oils to remove the coolant.
In terms of no spark and no lights, we disconnected all the wires going to the engine including the single black wire- still no spark. To me this indicates stator or CDI. For the lights we found the blubs to be good, however the plug for the main headlight was melted.
Any ideas would be helpful as I am about ready to part this thing out. I don't want to stick a bunch of money into this as it has 7000 miles on it and has had a pretty hard life.
