alley mechanic
We have a 98 skidoo mxz 440 fan cooled snowmobile, that when i started it up this year for the first time i noticed sparks coming from the four wire connector that comes from the stator to the wiring harness. The connector is mounted to the crankcase by a clip and a screw, when i unbolted it and inspected the four wire conector .ir had a melted spot on the btm looks like the yellow wire with a blk stripe touched the mounting clip. I ordered a new connector from skidoo , in the meantime i took out the wires from the connector and forgot to write down which wire goes to its matching wire the stator side has a blk wire , a yellow wire with a brown stipe a yellow wire ,a blk wire with a yellow stripe the harness side has a brown wire, a yellow wire a yellow wier with a brown stripe , a blk wire ,any help would be appreciated since i dont wat to guess .
