snootbiscuit
hey folks. rec. had to rebuild my 08 poo 700 cfi. w/ 6100 miles, after doing some reading, here and on hcs, I see some reports of valves hitting pistons. after further inspection, mine were getting close! I inspected the shoulder, on the guillatine,and it sure appeared to be worn. I ordered new ones. when I got new ones, I measured the shoulders w/ digital venier. the new ones measured just under .100", the used ones were under .070"!! I read where guys were grinding off, approx. .025 ,the front edge. I would have been ok w/ that, but the thing I didnt like was=if the integrity of the metal has been compromised, then where is the material going from here on out, into the cylinder!! also measured my 07 600 cfi w/ 2000 miles and those were over .100"!! I recorded all readings and I will be checking mine during cleanings here on out. just a last thought 4 some of you "metal gurus" , do u think the hardness of the shoulder is compromised over time, because of the "light pounding" on the shoulder from bottoming against stop in cylinders? sorry 4 the long post, just wanted to get this out to u guys,maybe save an engine or two!!
