Yamaha jet ski
arcticman
Hey guys, visiting a friend in Florida, he has a jet ski that will not stay running after it get warm. I have installed new spark plugs ran great out to the bay and at forty miles an hour it up and died. would not restart for several minutes. This a yamaha xl 1200 don't know the year.Act like the starter is not engaging and when does will only start with choke and 1/2 throttle. Help
mikes99ss
Check the compression first. Then check to make sure the choke isn't sticking. Assuming it's not fuel injected. Just my idea's
mjkaliszak
Do all the above,
There is a plethera of things that can be wrong. Very little info to troubleshoot. did it always do this or did it just start? Are you getting good cooling ? Check the pipe it should not be too hot ( sizzling ) . Does it have a pisser and is water coming from it ? Sometines the starter is right next to the pipe on some models. You have to rule out some things , try to jump the starter straight. Sounds that heat is effecting the ski because after it cools it is good ? A good place to ask some questions is PWC Today. There are quite a few knowledgeable people in each forum. Most of my stuff is old school & modified stand-ups. Check out the yamaha forum and do a search. That way you don't have to get activated . A lot depends on how( what words you search for )"like yamaha 1200 gets hot & shuts down". If you can post ( sign up ) and ask for help, you will get some. Hope that helps.
arcticman
He has decided to take to the dealer does not want me wasting vacation time working on it. I asked and said this is new just started. I will try some of the other things mention before it get picked up.
Thanks
