doo or die
I have a 01 summit non x package rear suspension, looking to find a way to make it sit a little higher in the back without getting a entire diferent suspension.... any suggestions?
I had an 01 and played with it till I was blue in the face. My riding was stand up back country style. The short answer is to get the heaviest rear springs available and set them as light as you can for your wieght. A stiffer front spring for the front of the skid helps. Do not lift the front of the sled with longer shocks or lowering the shock brackets unless you want to buy hoods and windshields. This is not a cross over/ dual app sled. It is a great carving, boondocking, through the trees sled period.
and when you talk about the rear springs, you mean the 2 torsion springs?
Not sure if you want to sit higher or you want more room under the tunnel. If you want to sit higher you could get one of the wedges that go under the back of the seat and on top of the tunnel.
the rear ladder is 9" on "96 to "07
new xp summit is "11 or "12
new xp ladder is hard to retro and $100's
cut old style add 3" (pro wielder)
move mount back 2.25"
install two up springs
open front limit strap.
