01 XCSP Backfire/Miss issues
snowkoch
Went thru carburetors and needle/seat twice, no blockages,etc. Will run top end fine, when let off gas it backfires, seems to skip a beat and occasionally won't idle correct. Anybody have any experience with this? I've had 3 people look it over and no clues yet.
lewisb13
Backfiring is caused when unburnt fuel hits the hot exhaust manifold and explodes there instead of inside the cylinder. This tells me that you're not igniting ALL the fuel INSIDE the cylinder head. Check plugs, timing, coils, etc...
artic570
X2 The throttle overide cable adjustment.
A friend of mine is having similar problem and he has no play in throttle lever.
I had a similar idle problem on another friends 550 classic. I adjusted throttle free play and all was good.
snowkoch
Thanks for the great suggestions. Exhaust gasket seems to be fine, will work on the throttle cable adjustment next. Tried to pull the fly wheel off (someone thought the key might be broken inside causing it to skip a cycle) but can't peel off yet. Might have plenty of time until next ride....
