I had a Viper.
1. Cleaning carbs is a way of life for Yamaha owners. There are great step-by-step instructions at totallyamaha.com in the tech section. 2. They run hot. Most people add a rear heat exchanger, if it doesn't have one. 3. Shouldn't be hard to figure out where the coolant is going. 4. If you take off the airbox, it is a PITA to get the carb boots back on. Loosen the clamps all the way, tilt the engine up, and push the airbox on at the same time.
