02 800 mxz
coldbear
Lot's and lot's of oil in the pipes after a year in storage. How did it get in there,anybody??
Gas drained after last season use.???? It smoked tremendously.Finally cleaned up but still has me wondering what caused this issue.
rbsracing
One possibility is that the check valve in the oil injection pump and or nozzels are bad not a big deal just will make a mess after sitting a long time with a full oil tank.
dab102999
Was your oil tank empty?? If not watch it the first couple of runs to make sure that the pump isn't broke and letting oil past it while it isn't runnin. If it is will cause your motor to hydraulic and blow up. Did you fog it or someone else?? Sounds like excessive fogging oil..it has got to go somewhere.
I know I always dump a little oil in the plug holes when summarizing and turn over slow.a over zealous shop kid could verry ez dump alot of extra oil and it would dump in the the exhaust port and sit in the pipe.my sleds look like fog machines 1st start of the yr
