I went to put away our 02 Legend and noticed that it didn't have any lights (head or tail or brake) the tach didn't work or anything electrical on the dash. It worked when we pulled it into the trailer. I did check all the fuses and connections. Could it be that my voltage regulator died? I don't think i has anything to do with it, but we rebuilt the motor this winter. Any suggestions would be appreciated.
dooforme, This should answear your question.
Well did some more research and found this on the hard core sledder forum:
Had the same problem with my 02 700 Legend 2 years ago. It was the relay - Ski doo part #410 113 200 ( aprox 22$ here in Canada). I picked the same one up at an auto parts store for $2.75(Suntech SEM - 1417) or NAPA AR - 201 or
Bosch 12 Volt - 30 Amp part #0 332 019 150. There are 2 identical relays on the Legend 700, one located beside the fuses, the other above the fuses. I replaced the one beside the fuses
http://www.hardcores...-no-lights.html
X-ref the Bosch part number at Advance Auto parts where work part-time and got a BWD R681Z, plugged in in and I got Lights. Not sure why swapping the two didn't work for me , but their was a post about they both need to be good.
http://www.johndee.com/vbulletin/showthread.php?t=22655
