A friend brought me his SDI that quit running this weekend. It ran two days without a glitch and on the third day it would not restart after a short break. Being that the conditions had a lot of moisture in the air, I brought it in and thawed it out. I have new relays and battery in the sled. I have pulled, inspected, cleaned, and greased all connections and I still do not have anything. It apppears that I have spark but I do not have 12 volt power past my RER/start switch. If I try to preprime the SDI or start it w/ elec start I get nothing. The main fuse on the battery is good. The main fuse on the fuse block is good. I have 12+volts to both relays. Battery ground lead is good and tight. If I hold , or repeatedly hit the start switch I can get relay to Buzz but nothing past this. What am I missing??? TIA!!!
