I have a 05 Skidoo Renegade, 600 HO, I'm the original owner, it's been meticulously well-cared for, and has a little over 7500 miles on it. I have a few questions regarding "preventative maintenance":
1) Does it make sense to proactively put a new top-end rebuild (new pistons, rings, bearings, etc) in a sled that runs great, and has had no mechanical issues thus far? Compression is running about 120psi in both cylinders (warm)? I guess my question is, is it cheaper to do a rebuild before it siezes up or wait until it happens. I plan on hanging on to the sled as a back up and for friends to ride, etc., but I know it wouldn't be worth crap if the motor was junk and I don't know when to expect that out of an 05 600 HO?
2) Same sled, has never had any drive axle maint done. Again, with 7500 miles, I'm looking for guidance on what items need to be replaced, looked at, etc. The only thing done is both primary and secondary clutches have been rebuilt and I go through the carbs/exhaust valves at the end of every season. Do I need to start worrying about driveshaft bearings, other things?
3) I tore off the carbs and replaced the carb boots, reed cages on the sled. When I did most of the antifreeze poured through the heated carb hoses. What is the process to fill up the tank with antifreeze to avoid air and get the proper amount, I remember something about having to set it uphill with the cap off and run it???? But not sure...
That should be it for now, thanks for your assistance.
