Tried to drain the oil, but think I stripped the allen nut.
Guessing I'm not the first to do this. Any chance this can be drilled out? Any ideas would be much appreciated.
Tom
The inside hex. It won't budge.
X2 on take the cover off so you can clean. It shouldn’t be that hard just have to get the muffler out first if I remember and have a little bigger drain pan because the oil will run a little bit.you take the cover off you can clean every thing , I have never used a drain plug
