06 X-FIRE motor mounts stripped
xfire7
I recently noticed that my Mag side motor mount holes were getting sloppy and about to rip through the mount itself. There was about a .375" play from side to side ??? Has anyone seen this before on a Crossfire...?
I did blow 2 belts last season and now think it was due to this slop and mis-alignment of my clutches ?
I have read a few posts about the mag mount going bad on xfire I was going to try to put on a solid one from a extra pack I have for a f7.
Falcon20
I've read this about the Fcat also. Fome the heat on that side the motor mount rubber deteriorates (sp?). There is solid mount that can be bought. Mine is still fine, though I did put silver reflective heat tape over the mount.
tequilamonsta
Pretty common on mine at least. Think I've done the mag side three times already. Tape is a good idea. There is a rubber stopper adjuster behind (under) the jugs, kinda hard to get at I thought.
