Hi All,
Just got back from a long back pack trip the last several days. Coming back to the cabin across Lake Gogibic we were running 70MPH, the engine just died, dash shut down right away. The mag side (exhaust side) had some detonation on the plug and on top of the piston. We just filled up with fuel prior and everything was running fine. Towed sled back to cabin as it appeared to be in limp home mode and only idled at 1400, not the 1800 or so it should be. Brought it back home today and did compression test. Clutch side at 120PSI, and mag side had 60PSI after three pulls on recoil and then compression went to zero. Plugged sled into the computer and no unusual fault codes came up. The sled has 3488 miles on it. I pulled the exhaust valve and all looked ok. We will pull head off later in the week to find extent of damage. My question is why did the engine just completely shut down? I don't want to rebuild the motor and find there was another root cause that did this. I know reading some threads there was a stator issue, however seems to have great spark. Please provide any feed back. Thanks
