08 ac f8 lxr handle bar heaters.
mgsimon
I just bought an the f8,the left hand heater does not work.
I removed the switch assembly checked the continuity on both settings I ad good readings on both.
I them tried tochecked the voltage ut could not determine the groung.
It is a three wire connector.
Can anybody give me some guidance.
thanks
ma
Mark
cant help u on testing but my f8 left also went to pot and it pretty much sucked replacing the warmer wrap. now that I think about it my 10M left went out during test drive when I was selling odd
3_old_jags
The AC manual says to check the handle bar element at room temperature of 68 to get the correct ohm resistance.
Green/white wire to green should read 6.3-7.7ohms
Green/blue to green should read 12.6 - 15.4 ohms
Manual says to replace element if lower or higher than specified.
My daughters F5 just had the left go out last weekend so I have some trouble shooting ahead of me next trip north.
