snowshark94
I have a problem with my 08 700 daragon that it only hits 7000 rpm now when it should hit 8250 RPM. I was racing down the trail at about 95 for about 5 miles and at the end of the run it would only max at 7000 RPM and will only hit 72MPH. I then changed the plugs (1 dark brown, 1 light Brown) and put a brand new polaris belt on it and I had the same result. The sled starts fine, seems normal idling, it has no bogging, I cleaned the exhaust valves 400 miles ago, it basically runs like a 500. I have a Goodwin performance clutch kit on the primary and secondary that has been on the sled since I bought it new. I rode it for an additional 150 miles, took plugs out and they look fine.
I have never cleaned either of the clutches, Is something maybe sticking, so will that cause it not to hit its full RPM? Does anyone else have this problem? Can it be a dirty clutch?
Any advice would be appreciated.
Thanks,
Mike
Thanks,
Mike
