they claim full syn is not the best for crank temps www.yamaha-motor.co.jp/global/about/craftsmanship/technical_review/publish/no35/ pdf/0008.pdf I had also been reading the same about full syn over at doo talk. talking about surveys about crank bearing failures and full syn use.not that doo is the best base line for crank bearing failure testing but if you need failure results they work.they were saying over at doo the number of full syn crank failures are about 80% compared to 20%with semi syn witch makes sense after reading yami crank temp tests
