OK, snowmobile started cutting out a few yrs back, so thought it was a fuel pump issue, replaced fuel pump same problem. so next was the TPS, but this came as a whole assy not just the TPS Switch and still same problem, now the fun part, this snowmobile is equipped with a remote start! is there a way to bypass the remote start to see if this is the starting/running issue? it will start and idle with the TPS unplugged, give it gas and its sputters and cuts out, Plug the TPS back in and Nothing! my question?....... remote start? fuse somewhere? ground wire? throttle body sensor? anyone ever had this happen to them that can shed some light on the fix?
