Talked to the dealer in Wisconsin, no recall on 800 IQ or 800 Dragon. The problem is the single ring breaking on the piston. The 2010 models will have 2 rings, so Polaris is testing this and will have a answer to fix the piston with a double ring. Some 800 sleds are perfect and others are locking up, the new reflash will lean out the motor and run alot better.
The il dealer I talked to today also said the same thing piston rings breaking leading to motor locking up.
Polaris has a 2 year warranty on the 800 IQ and 800 Dragon, so we are covered for all of 2009 and 2010.
What it looks like Polaris will have the dealer inspect all 800's this fall and check the piston and rings, if bad replace piston and rings.
Polaris also claims the reflash did not cause the pistons to fail, some pistons are defective, is what they are finding out.
So it is a gamble some 800's are good for thousands of miles, others blow up under thousand miles.
There has not been a recall so far on the 800 IQ or 800 Dragon, everybody who says so is full of BS!
If so prove it!
