How do I get this sled more nibble for UP riding?
It just seems stiff, when you stand up and rock it back and forth. even with front shocks down to 45lbs.
It has heavy steering going thru tight trees.
I'm 175 lbs. running the Fox shocks at stock settings, for my weight.
65lbs in the front 125 in the rear with the front skid shock pretty loose.
Limiter strap middle hole.
Skis one adjustment from being narrow as possible.
I ride my buddies Freeride and it just is way more nibble and easier to maneuver.
His steering is much lighter, when riding just lean and it will turn.
