HMM,
I am betting it is an issue with a wire rub through on the frame.
You will need to pull out the wiring harness from underneath the motor. Unhook the harness from the front of the sled, and tape a small diameter rope to it. Pull the harness out from the rear of the sled and look for rub through area. Fix those areas, and use the rope to fish the wire harness back through the underside of the engine (or route the harness over the top side of the engine).
I sent you an email
