Or if you are up to it, turn the ign. off hold the throttle wide open and pull it over 100 times. That'll get any air out of the system LOL
Or, remove spark plugs, cut off the female end on a 3/8" extension, chuck it up in a 1/2" drill with whatever socket you need, go thru the belly pan to the clutch bolt, hold the pump wide open and let the drill do the work.
I have done this....
