It's all about the resistance. The unit will not likely ever pull more than 20 amps which is near the load that the circuit breaker will allow. If it exceeds that, the breaker trips...no big deal.
Just remember that resistance also factors into the "run" to the unit.
That is why they sell huge cords to carry the load better without...heating up that cord. If your cord gets HOT, then you are exceeding it's capacity to carry the load and you can melt that cord down to a fire, or if your lucky, it will short circuit, and blow the breaker.
So keep the "run" short, use the approved cording or greater, and then see what happens. If it blows the circuit then you will know that the unit is drawing more than 20 amps.
Starting AC compressors or Refrigerators or any other electric motors always draws the most, and I agree that you should not try and run everything in the unit that can draw more juice....such as micro, fridge, etc. Shut them off.
Now someone else mentioned that the camp ground can have a draw down of the power, aka, brown out...those are different...cause you are now not getting 120 volts....more like 80-95, and when THAT happens, you can destroy the unit that is running, and this doesn't stop at your camper, this includes your home well pump, fridge, AC, etc. A brown out protector senses this, and will shut the juice off if a brown out occurs.
If you go to a camp ground that shows the lights dim alot, get a voltage meter that simply plugs into an outlet in the overhead and as you walk by, you can see what the voltage is....if it goes up and down a bunch...disconnect and run from a genset. You will save yourself a bunch of dough.
