I've pretty much established that the o-rings need to be replaced. My first question, is that since it was ran dry (i lost my coolant due to a stud) it sat for a little bit, could the o-ring have dry-rotted?
Onto the next question(s)-i think i know everything i need to do, please correct me if i missed a step.
Start by draining coolant. Then, Take off the head bolts (in criss cross pattern). Next, take off the coolant hose off the thermostat, but don't take off the thermostat. Next, take off the head. Take off old O-rings, scrape/clean it. Next, put new o-rings on (do i need some special o-ring grease?). After putting them on, put head on, put bolts on, tighten in criss cross pattern (do i need loctite on the bolts? or anti-seize?), And torque them (18-19.5 correct?) connect all hoses and bleed??? anything i missed?
sleds a 99 polaris xc 700 btw
