sean34590577
Suspension broke last night up by the front shock on 1 side. Going to have welded in the a.m. Any tricks to take the suspension out and in? Thanks for all your help! Love the info. you get on here! Thanks John D.
Use a sharpie and mark the rear track wheel adjustment bolts before you loosen them up
I wouldn't, i'd reset the track tension. 16" from the rear wheel, i like 3/4" sag I've tried it all from 1/2" (which is 1" with a 10 lb weight on the track, what the factory recommends) all the way up to 1.5" sag and i prefer 3/4".
Nothing hard about it. Loosen tension on the rear bolts (like dave b said) loosen tension on torsion springs. Unbolt the rear 2 first, then the front 2, pull er out. It helps to have a chain hoist or it works to tip on the side but i prefer chain hoist.
But also keep in mind this tip only works with a chain hoist.
