So the sleds an 05 Switchback 600 144". I just installed a 2" paddle track on it and regeared (drop tooth on top and up 1 on bottom) now before you think that had something to do with it, it did it riding around my yard with stock gearing and track. The only changes I've made to the clutches are I added Delrin washers in the secondary (it has a team secondary). I've adjusted the track between 1/4" sag and 1.5" sag. I've tried 3 belts. I've had the primary apart, literally EVERYTHING looks brand new. The sled has 1400 miles on it no rusting no wearing in clutches whatsoever all the belts I tried were dang near brand new. Now, before you think track ratchet, not it is not the track ratcheting. This only happens upon SUPER SLOW acceleration from a dead stop. Once I'm going its perfectly fine. Now I held the hood open and the clutch guard and watched as I slowly accelerated. The clutch would grab and release, grab and release, grab and release, hence the belt slipping. Am I going crazy here without snow to test this? I mean my C&A XTX skis with 10" carbides dig into my grass HARD, being a longer track also, is there too much friction causing the sled to do this? I'm out of ideas, just wondering if anyones had a similar scenario!
