Hi was wondering if anyone could tell me what is causing a weak spark on recoil side cylinder.i was told it could be a bad ground but could it also be the stator going bad?Thanks for any advice you guys can give me.
that sled has 1 coil right?if so pull both wires off coil swap around and see what happens could be a bad wire or bad connection or bad coil but that would be odd if it is a single coil
yep single coil.coil was bad.put new one on works fine.now i have a carb issue. what causes a carb to warp so that the barrel will not slide freely?lot of ridges inside the carb where the barrel fits
