arctic cat thundercat torque specs
fastmax05
Need spec for primary clutch just replaced bushings and primary spring need to know spec for the cover bolts, primary clutch bolt to shaft, starter ring bolts on back of clutch and any other info would be great and very appreciated
acatzl550
if its a 9 post clutch its 10lbs, and if its a 6 post clutch its 7 lbs torque for cover screws....and the clutch bolt onto the crank shaft is 51-56 lbs
I do not torque the bolts on the clutch cover, just put loctite on em and tighten em until they're to the point before they dont break, and make sure you DO put loctite on the clutch cover. I put some on my clutch bolt that holds it onto the crank too because i had a tiny bit of grease i couldn't get cleaned out of the threads. I put medium strength on the clutch bolt and high strength loctite on the clutch cover.
