Are the Extra 10 supensions adjustable?
awbrennan
I Have 2 Sleds with extra 10 suspensions. one a Indy trail touring and an Indy trail. The touring sets much higher and I noticed the limiter strap is conected differently on the touring sled. I want to raise the suspension on the indy trail. What should I do. I would like to raise it as higha s possible. Thanks for the help
sleddog66
Not sure what you are after, but a couple of things. The springs at the back can be set to the stiffest setting. The coupler blocks can make the front end very light, or not. The limiter strap can be adjusted. If you are just looking for tunnel clearance, you can pull the rear skid bolts, and put them in the bracket that is attached to the bottom of the boards. It should be a black steel bracket.
I have the M-10 owner's manual in a pdf file that I could email you when I get back home. I'm in Louisville on work right now, but will be back late Friday night. My email address is listed in my profile if you're interested.
m-10 is a whole different suspension
